Carb question non CR500
Travis
Post by Travis »
I had to change the carb on my qua because they 400ex has a pressed in seat that cannot be changed apparently that had went bad. The new carbs were $300. I picked up a parts bike for $50 and used it's carb. Here is where I have ran into trouble. It idles good, and from 3/4 to WFO it runs good. At a cruise in high gear or any gear at about 1/4-1/2 throttle it will bobble a little and stutter. It will sometimes backfire and stuff when you keep the throttle in that range. I could not find the chart that shows what part of the carb it is using around that range and I cannot remember. Help me out guys.
Travis
89 CR500
01 Banshee
Dakota Boy
Post by Dakota Boy »
needle
1984 CR500 owner
Racine, WI
yup, thats all needle there. :wink:
Travis
Post by Travis »
I think I will pull the one out of my old carb and stick in it. It ran tits with the old carb on before it went to overflowing and flooding without end.
Travis
89 CR500
01 Banshee
