Oversized
honda02
Oversized
Post by honda02 »
Which oversized gas tank will fit my 2005 CRF450X conversion.
What I have read from others I need to make sure the new tank has the same lowwer tank floor as stock or it will hit the motor.
I would like to use the stock shroud and a see through type tank.
Will a CRF450R tank work for me??????????????.
From what I have gathered from all the info on here and also when I built my AF, you will have to modify pretty much any tank for the conversion, but don't quote me on that.
honda02
Not Mod
Post by honda02 »
My Stock CRF450X tank fits with out any Mods.
If you have some spare $$$$ you could get someone to weld up a beer can version for you.
That way you can shape the bottom of the tank for the clearance the bike needs and get more volume as well. :wink:
honda02
Welding
Post by honda02 »
I can do all fab work my self but I need to get the filler cap part made and buy a welder.
But I rather have a plasitc tank.
CR500R7 wrote:If you have some spare $$$$ you could get someone to weld up a beer can version for you.
Thats what you want, thats what you should get.
It was just an idea. :cool:
Bean
Post by Bean »
you should be able to fit an ims tank . i have one on my 09 450x / 500
the base of the tank is about the same as stock. if you need to you can fill the tank with boiling hot water to soften the plastic enough to mold it around the spark plug
honda02
Thanks
Post by honda02 »
Thanks I get one.
shaggy aus wrote:you should be able to fit an ims tank . i have one on my 09 450x / 500
