Somebody run a Marzzochi magnum 50 in his CR500?
- xtremeslide
I have this KTM (Needs new piston,cylinder and rod) i want to put the forks in my "new for me" CR 500 Enduro conversion meanwhile i'm waiting for the money(AF),comments and constructive ideas please...What i'll need...i don't know nothin' about suspensions,all the advices are welcome
CR500R
V-MAX 1200
V-MAX 1200
- redrocket190
If anyone wants to supermoto their CR500AF and swap the stock Showa forks, wheel, brakes etc. for a 50mm Marzocchi setup with a Brembo radial disk let me know. My Husqvarna SM510R is basically a TC/TE bike but with a lower SM-specific front-end. I would consider converting it for off-road if I could swap the front end. It's too expensive to do a parts swap to convert the SM forks and brake for the TC/TE version.
Michael Stiles
2007 Honda CR500R-AF
- xtremeslide
Well if fact i thought the forks was Marzzochi(mistake)...but i think youryota wrote:are you sure those aren't WP 50mm Extremes?
right the
brand is WP KTM offered both,I want this forks for enduro i think it could works better in the
stones paths than the stock ones,that's because i ask if somebody have
tested they or other 50mm
CR500R
V-MAX 1200
V-MAX 1200
south central hoon
I think the 96 did have zokes, the Wp extremes didn't show up I think until 98? the extremes are one of the best conventional forks. The best was the big Showa conventional that was on 97/98 Rm's and believe it or not DRZ's (with dif valving of course). Changing forks isn't that hard, you may have to machine bushings to use different stems and or axles. I put a set of the big Showa conventionals on my Maico with a little machining and a hand made brake stay.
