In Frame Top End
In Frame Top End
What Gens if any can you replace the top end without pulling the motor?
I'm doing my mounts now on the 03 crf450 and got to thinking about this.
if i leave the swingarm bolt in, remore the 2 lower mounts and headstay i can install and remove the jug easily with the OEM mounts for whatever still intact. BUT the head needs to be removed first.
AngryShawn
I only need to move it 1/16 of an inch or so to get past that stock cr250 whatever bracket that i left on the frame, without it the bolts could stay in
Off topic, but I noticed the decomp valve in one of the pix.
I amd still thinking about that decompressor, Roostius the lack of $$ is holding me back...but can you post up a few pix? Wondering if a 4-stroke hot start lever can be adapted to it.
I was curious about the decomp too. What are you charging to fix up a head with one of those?hoofarted wrote:Off topic, but I noticed the decomp valve in one of the pix.
Travis
89 CR500
01 Banshee
89 CR500
01 Banshee
