Frame Components
Frame Components
I hope someone knows,
On a 2002 CR250r. The lower frame component between the footpegs. It appears to be solid, or billet. If it is I want to drill & tap holes in it to mount the skidplate. Can anyone tell me without any doubt?
- asteroid500
id use the proper brackets because when you case this sucker out on a log or hard pack (depends on your riding disapline)...(oooooo what a filthy word) if theres not enough material there your going to shank or drag the nut in the frame and only flog it out.
CR250 97
CR500 AF 99 (in progress)
CR500 AF CR G-4
CR500 1985 true legend
RGV250 96 X2
GSXR600 07 TRACK BIKE
VH Commadore cup car (race)
						CR250 97
CR500 AF CR G-4
RGV250 96 X2
the gen3 i bought had the skidplate welded to the back in the area you're questioning.
I had no clamps for that after i cut it off, so i hit the mill, if oyu need some let me know. They're wide so they fit over the weld at the widest part + had the most clearence everywhere.
I guess the first thing I will have to do after my rebuild, is learn how to post pic's.
In the interest of better handling and mostly, less fatigue, I am putting the coil,cdi,and battery between the skid plate,(carbon fiber) and the engine. There is lots of room. This will take 2lbs 4oz and lower it 20 inches, and move it from as far as 20" in front of center, and 10" behind center, to center. I think it will be noticible. Only time will tell.
