dimpling cases
seanmx57
dimpling cases
Post by seanmx57 »
Hi. Does anyone have input on dimpling the main cases between the tranny and the crank? How about between the case and the jug. I have never sucked a gasket and don't want to. I'm getting ready to throw her back together once I get my crank back from STR. Does anyone use yamabond on the center case. I have always used a thin coat of red RVT on the base gasket for cylinder with good suceess, but I don't have a million miles on 500's yet.
no need to dimple. I've never sucked in a center gasket. have w/ a cheapo base gasket, only use OEM or cometic base gaskets. don't use rtv on base gaskets, fuel eats it. yamabond is ok though.
fastkart
Post by fastkart »
The cometic base gaskets have a steel shim inside them... thats all I use.
fastkart wrote:The cometic base gaskets have a steel shim inside them... thats all I use.
I lost a gasket from the crankcase to trans, i threw them on the mill and cut .003" to make it flat again, the other side took .008" No problems with trans shimming either. I've cut some junk ones too see how far i can go, so now I cut them all now before they go together.
I just torque the shit out of them :D
Yamabond at the crank to trans. But then mine are slitely missmatched because of a piston frag. :x
DesertCR
Post by DesertCR »
Ive got a left crankcase for a cr250 that is very uneven, I'm wondering if I could mill it enough to make it flat again. Its got a low spot where the crank is. I guess it wouldnt hurt to try.
seanmx57
Post by seanmx57 »
anyone ever use hondabond 4 ?
The yamaha shop said it's the same and they didn't have the yamahopper stuff.
DesertCR wrote:Ive got a left crankcase for a cr250 that is very uneven, I'm wondering if I could mill it enough to make it flat again. Its got a low spot where the crank is. I guess it wouldnt hurt to try.
I tried to do some with multiple different cutters before getting the CBN button, I wouldnt recommend anything else now. It finishes like mirror and will cut even with a load of only .0003" on my Rottler
Roostius_Maximus wrote: It finishes like a mirror
I always though you wanted some machining artifacts to give the gasket something to hold onto?
Yes / No ?
seanmx57 wrote:anyone ever use hondabond 4 ?
ive used hondabond but i cant remember if it was 4 or which one but its real runny like syrup. if everything is straight and not warped, you dont need any sealer on any of the gaskets. infact its probly better you dont use sealer with honda gaskets. ive used sealers in the past and they worked fine but the next motor i do, i doubt ill use sealer
Yes / No ?
You're right, Its RA is a shiny finish, is exactly the process the cases were machined with factory, i'm using "mirror" more to define it not beeing a cut with a trailing ,scraping, or any other mark that can be left by carbide, high-speed-steel, abrasives, or other method.
a better look at cases refaced are:
