So I had the opportunity today to service the stem bearings. Since it has gotten cold, I could feel a definite catch when I turned the bars while the bike was on the stand. I guessed that they had never been serviced and I was right. Top bearing wasn't too bad and still had grease on the rollers, but bottom bearing was terrible and the rollers were pitted and rusted badly. I guess moisture collects around the bottom bearing from sitting outside or some dumbass blasting away with high pressure water---or maybe just condensation.
Ordered new dust seals, bearings.
What's the best way to remove the old bearing races? Tap them out with a drift? How about going back in too?
Stem bearings
Stem bearings
Re: Stem bearings
Yea.... drive them out.Exnav wrote: Tap them out with a drift? How about going back in too?
Put the new ones in the freezer overnight, and they almost fall back in.
edited for a misspellingDaveedo wrote:Which brand of bearings did you get?
Looks like honda used nachi and toyo which are pretty good. Not sure what pivot works or all balls use.
