Build up
kkvslayer
Build up
Post by kkvslayer »
Puttting her back together,should my tranny spin freely once the cases are together?I spun them before tightening the case bolts and it spun very easily now there is some drag and even a little noise,should I tear it back down,I ve never did this before so I don't know what to expect
1994 Heartless CR500R
1986 KX500
I would pull it again as something is binding, did you make sure to put all the shims in the rite places?
kkvslayer
Post by kkvslayer »
britincali wrote:I would pull it again as something is binding, did you make sure to put all the shims in the rite places?
Shims?You mean washers?I double,triple checked but I guess something is wrong,no choice but to tear her down I guess,maybe I'll get it right next time,Thanks for the quick reply
1986 KX500
Shims-washers-spacers whatever :lol:
It doesnt take long to pull it and check everything to make sure its good. If you have a manual go through it slowly step by step to make sure everything is in the rite order.
97af
Post by 97af »
Give the countershaft a semi healthy dead center whack and lighty tap on the crank ends before you split it again. I'm betting that will do the trick and un- bind things for you.I threw one down a flight of stairs once to "seat" everything up. :lol:
bigpower
Post by bigpower »
97af wrote:I threw one down a flight of stairs once to "seat" everything up. :lol:
Sounds like somethin I'd do
