what clutches are you running
aloha450x
Post by aloha450x »
talk to me. wha clutches are you running?
MICK
Post by MICK »
Used a Hinson basket with OEM plates for several years. This summer I put the OEM basket back in (modified) with Hinson plates. Feels better now than it has for many years...although I doubt it feels any different than the next freshly broken in clutch.
i use oem plates and never had much issue. any clutch should last for a while, provided you dont SLIP it through a 4 mile mud hole like the guy on the other site :roll:. if your worried about shavings in the oil then use steel plates. i thought about using steel plates and i might when my aluminums wear out but im not sure, i dump the oil every ride so i aint really concearned about the contamination. i also use heavy duty springs.
Barnett Carbon
Hands down.... the best.
A new Barnett dirt digger is the best clutch you can buy, period.
Ported&Polished wrote:A new Barnett dirt digger is the best clutch you can buy, period.
X2 :wink:
Barnett baby !!
