i emailed some people looking for a clear cut response and i really havent got a difinitive answer, not sure if nobody wants to discuss this subject or what the deal is :? . on the gen4 crf250r, if the front and rear sprockets are perfectly aligned, will the exhaust manifold be off center coming out the Y ? ive seen somebody say they had this problem. just wondering how far off center it is and if its common problem or isolated case ?
Hopefully I'm going to throw this one up on the bench again thisafternoon, I'll let you know.
On mine, everything is aligned...
juddy
Post by juddy »
You have to have the sprockets aligned,no choice in that.But I had a look on mine and the exhaust looks central to the Y to me.I used one original spacer but on the other side,and a spacer from a CR 125 (59 mm :o ??) I think it was.
doesnt seem like many people on this site are doing the gen4 250f conversions. hopefully more folks can chime in with their experiences
juddy wrote:..... and a spacer from a CR 125 (59 mm :o ??) I think it was.
Pretty sure 58mm. 2003
100hp honda wrote: hopefully more folks can chime in with their experiences
Your hearing 2/2 that is aligned...
What more do you want to hear?
X2 No Shit. :roll:
south central hoon
Post by south central hoon »
your frame might be tweaked a bit....
chachi243
Post by chachi243 »
welll noow easy hoons..... i think i had stated that in order to get them aligned, i had to use one factory slug with a shim and grind the other one down...... and i had already flipped the countershaft sprocket supermoto style to gain a tick more offset...... whether the chassis was tweaked, well i couldnt get access to hondas jig, but i did have to flip the countershaft to get the exhaust port centered with the Y. see my angryshawns build for the pics.......also, his was an X model frame for what its worth
*builders note* it could be a case by case exception as all chassis boing a little one way or another as the sawzall removes the entire lower assembly, not to mention that there is a tick of side to side swagger in the motor itself even when the swingarm bolt is in place.... maybe Shawn's frame was hanging out in the garage too much and loaded just a tick.
I havent got a chance to look at this one, Too busy this week
