real 80hp
real 80hp
haha just joking its only 60hp i think
. i try to figure out this carb but i dont know. can someone tell if the engine sound is good or i make the main jet smaller ?
- xtremeslide
south central hoon
6,300' , 80 degree temp, stock motor, stock pipe, stock carb, stock reeds cage, stock head. 50 pilot, 1370 needle, 170 main. with this combo it was doing tits
here what it is now: same elevation, 40 degree temp, roughly 190* exhaust porting, loomis head, fmf narly, rad valve, stock carb. 52 pilot, 1368 needle, 175 main.
i will try the old carb setting again to see. i think it might do better with 50 pilot, 1370, 170
AlisoBob wrote:6.3k @ 80 degrees is a bout a 160 / 158 main...depending on humidity..100hp honda wrote:6,300' , 80 degree temp, 170 main. with this combo it was doing tits
Your leaving alot of hp on the table, Homes.....
i know. i got bag of jets from your buddy john so i can figure it out. its hard to tell the motor sound with a helmet on so i asked the professionalsAlisoBob wrote:6.3k @ 80 degrees is a bout a 160 / 158 main...depending on humidity..100hp honda wrote:6,300' , 80 degree temp, 170 main. with this combo it was doing tits
- NightBiker07
Ive tried revving the shit out of it and short shifting to keep the RPM low, as long as you have the right gearing short shifting low revs win out every time, especially with nitrous.
Motor sounds good, maybe a little fat? But it sounds to me like your kicker is slapping the pipe, or the springs are singing to their own beat against the header? Something making a "tingy" sound that isn't the motor itself.100hp honda wrote:its hard to tell the motor sound with a helmet on and all the rattles so i asked the professionals
south central hoon
south central hoon
sounds great, unless you are lean to begin with and go leaner. It will run pretty damned hard lean until.... squeeeek!AlisoBob wrote:Yup.....MICK wrote:I always preferred riding the bike back to back with different jetting. What pulls the best and / or runs the cleanest gets the job. I never put much emphasis on trying to read a spark plug.
