TWIN ENGINE CR500
xtremeslide
TWIN ENGINE CR500
Post by xtremeslide »
I watched the video with RPeterson riding the CR 1000,have some of you guys more info about how this bike was made,transmition,etc...
CR500R
V-MAX 1200
i think hamilcrf on the other site owns it now. he could tell you how it works
can you link to that vid?
aloha450x
Post by aloha450x »
so he didnt win? who was first?
rpeterson
Re: TWIN ENGINE CR500
Post by rpeterson »
xtremeslide wrote:I watched the video with RPeterson riding the CR 1000,have some of you guys more info about how this bike was made,transmition,etc...
The motors are connected with a jackshaft double sprocket and both run independently. All gears were takin out except 2nd.
RP
2nd gear makes more sense than 4th like hamilcrf runs
CRMOE500
Post by CRMOE500 »
Roostius_Maximus wrote:2nd gear makes more sense than 4th like hamilcrf runs
Maybe because 4th is physically bigger and stronger to handle the abuse? Just change the final gearing. Throwing out ideas, but there is always a reason. I could ask Ken and see what he says. Besides it has always peaked my interest when guys mod there transmissions like this.
Fins Rule!
Liquids drool.
xtremeslide
it has always peaked my interest when guys mod there transmissions like this.[/quote]
x2
CR500R
V-MAX 1200
2nd gear would only require 3 gears and one shifter fork, and its ALOT stronger gear than 4th that needs 5 gears or custom spacers and 2 shifter forks. but the contact width is 70% of 2nds.
If your trying to save alot of rotating mass 2nd is the way to go.
Roostius_Maximus wrote:2nd gear would only require 3 gears and one shifter fork, and its ALOT stronger gear than 4th that needs 5 gears or custom spacers and 2 shifter forks. but the contact width is 70% of 2nds.
:wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink:
CRMOE500
Post by CRMOE500 »
Thanx for the info. Could you maybe post up a pic of a modified trans for us to see?
Fins Rule!
Liquids drool.
in 2nd you have only 1 fork on the blue gear (4th) which is used to carry the green gear
in 4th you have a shifter fork holding 3rd(green, that carries the purple gear of 4th) and 4th(blue) and likely the 2 gears of 2nd(below 4th in this pic) to hold the gears in place anyways.
I suppose if you didnt need neutral at all you wouldnt need any fork, shifterdrum, or lever.
kdizzle
beautiful!
Post by kdizzle »
lewisclan wrote:Image
That Vid is as good as any pron i have seen... Dude has a set of balls to jump that monster and give it the nads on the way up.. man that got me fired up im going to get on the 5 and piss off the neighbors!
:headbang:
