![Image](http://i304.photobucket.com/albums/nn171/robertgalka/CR250ig.jpg)
1997 CR250 Ignition
1997 CR250 Ignition
Complete ignition from 97-99 CR250. I bought it but never used it, and I have no way of testing it. The seller said it came off a running bike. $60.00 US funds, plus shipping.
That looks like it is the rectifyer for the lighting coil.
Last edited by Ported&Polished on January 17th, 2009, 12:58 pm, edited 1 time in total.
It's supposed to be digital from what I know. I haven't even had my bike running yet, it's still in pieces. I don't know what that stuff on the CDI is, Maybe a voltage regulator?100hp honda wrote:i wonder if thats a digital cdi ? what do you think that stuff is on the back of the cdi ?. why didnt you try to run it atleast once ?
To make this fit on a 500, the center hole in the stator plate has to be made bigger.
Its the regulator....For the electronics on the carb......100hp honda wrote:i wonder if thats a digital cdi ? what do you think that stuff is on the back of the cdi ?. why didnt you try to run it atleast once ?
There is a spare set of wires that go to a sensor on the carb. I don't know if the throttle position changes the timing or the RPM changes something on the carb.
I was thinking if the timing is varied by the throttle position, it wouldn't take much wire in a switch and a couple of resistors to change the timing curves.
If anyone is interested, I'm sure $10.00 will cover shipping.
![Wink :wink:](./images/smilies/icon_wink.gif)
I have a vacuum powere power jet on my mikuni, during extended periods of WOT it lits more fuel in to avoind a lean condition. a 2 stoke can't be held WOT for very long without seizing unless you have a powerjet.
![Image](http://www.e-imagesite.com/Files/nitcirc117832991.gif)
well, let me rephrase that... to run an ideal main jet for the best possible throttle response would leave to lean as all fuck by a certain rpm and sustained WFO, a powerjet allows you to run a %20 leaner main, so she is crisp as fuck even at super low rpms being slapped open and the powerjet starts delivering when vacuum is created after the slide.
My gen-4 runs wfo like crazy on a 170 but she'd run freaken awesome on a 135 main with a powerjet![Wink :wink:](./images/smilies/icon_wink.gif)
but, both of you do realize that you may not have gotten dangerously lean, but you are leaning out any 2 stoke holding her open... it really takes a lot of abuse to damage them though.
I'm not pulling this out of my ass, DeWayne and I had a 2 hour long conversasion about it and I have a feeling he knows a thing or two![Wink :wink:](./images/smilies/icon_wink.gif)
talking from your 125 experience - loldannygraves wrote:yeah, that is the problem... they always run the best right before they squeekbritincali wrote:Lean is mean period![]()
It does fuk stuff up tho![]()
So back on topic - will this setup work on a 500?? Or would it just be better to get a 94-96 setup?
![Image](https://bannedcr500riders.com/images/auto/8615d306b6c50969b4983567db4298b1.gif)
Nothing is going to be as easy to swap than the 94-96 stuff. And provided how well it works it's hard for me to entertain the thought of using anything else?
However...
I haven't read a good review on the digital systems. It could be those 97+ ignitions work sooo good it's worth the pain in the ass to mount them. I've read a number of guys say they run the digital systems, but don't have much to say about them? So I say someobody try it already and provide us with decent feedback. I'm a grunt so I like looking at pictures, if whoever would be so kind as to make a graph like I did, it would be greatly appreciated![Wink :wink:](./images/smilies/icon_wink.gif)
However...
http://cr500riders.com/cgi/yabb/YaBB.pl ... 205070/9#9
I found this on the other site, but it doesn't say much.
