Radiator selection for Gen3 CR250 conversion
Just got my roller undressed and have lined up a local welder. Both aluminum frame and CR500 motor are laying around the garage eyeing each other as if they're getting ready to fornicate. I'm off to see the welder on Friday.
I'm wondering if there is an ideal radiator set to use for a Gen3 conversion? It seems like I've seen a few posts of folks using CRF250 rads. Any help would be great.
Thanks
Thanks
they wont fit your gen 3 tho
- teemtrubble
I really like the CRF250 rads with minimum coaxing the bolt up to your shrouds you have to relocate the mounting tabs and cut off one spout plug it and add one to the bottom of the right side Rad preferably a CR500 lower spout to maintain the same hose size and the angle is already correct
the stockers for the 2 stroke platform
i have always used the stock 250R 2 stroke rads in my CR250R builds...... just relocate a spigot on the right side and tweak the center ports at the bottom with a socket and an extension
Re: the stockers for the 2 stroke platform
Exactly...such an easy mod it took me two seconds to bend those spigots inwards away from the cylinder...and that's exactly what i used a socket extension...and if you use your stock 250 rads then you don't need to chop and relocate your rad mounts...be careful about raising your Y so that it doesn't interfere with the radiators...it's very very close.chachi243 wrote:i have always used the stock 250R 2 stroke rads in my CR250R builds...... just relocate a spigot on the right side and tweak the center ports at the bottom with a socket and an extension
I used my cr250 gen 3 rads. Right side got the spigot removed from the side and put on the bottom. The 250 hose was a whore to heat up and stretch over the cr500 engine side spigot, but I got it on there. Mylers did all the mods for me, straightened them, and sent them back in one day.
