Duramax Suspension
Duramax Suspension
My truck sits like a "Stink-Bug", and dosent ride like Iwant, so I made some changes.... Heres where I got some shocks... good price and service...
http://www.norcaltruck.com/shop/product ... 209deb8f17
Bilstein [BE5-D146-H0 & BE5-D147-H0]
So, I installed the shocks, and a 2" drop shackle kit in the rear...
( Ground Force Part # 91143 )
Nice mod, Truck sits level without cranking up the front "A" arms and topping out the suspension.
Truck rides way better, but to be fair I found that I had a dead shock at the R/R location, no damping what-so-ever.
Joshwfl
Post by Joshwfl »
Sweet, that's a nice price too :cool:
dude, you LOWERED it???
but its torsion bar... so easy to lift the front for leveling.
those are some nice shocks :wink:
I cranked the bars on my 04' and then it really rode like shit. :D
dannygraves wrote:dude, you LOWERED it???
The front suspension needs to sit at mid -stroke to work. If its topped out, you have effectivly eliminated all rebound.
You lower the rear....
I did a 2 1/2" front lift on my f-150 to clear the 33's and didn't have any problems, of coarse, that truck uses a macfearson strut and I just had to put a spacer on top of it. the ball joints could still go all the way down, so I guess it did'nt really have a negative effect.
robertg
Post by robertg »
I cranked up the torsion bars on mine and the shocks topped out before the suspension did. I was going to get the Bilstein's but I cheaped out and made my own shock extenders. I can stick my fingers between the the upper control arm and the bump stop, so it's not topped out.
The ride is still OK, but I don't off road at all. If I was going to do some off roading, I would buy Cognito upper control arms, and the Bilstein shocks.
robertg
Post by robertg »
This is how it sits.
Image[/img]
robertg wrote:I cranked up the torsion bars on mine and the shocks topped out before the suspension did.
I was surprized when I took the OEM shocks off, the "A" arms dropped another 1.5" or so....
Friggin GM....
The shock part numbers I listed correct this situation.
i would have gotten longer bilstiens for all four corners and turned up the torsions a bit.. its never going to ride like a car its a effin TRUCk for crying out loud :D
Re: Duramax Suspension
AlisoBob wrote:My truck sits like a "Stink-Bug"
all fullsize trucks are like that. because they assume you will have heavy loads in the bed.....aparently your using it to fetch groceries ? :roll: :lol:
100hp honda wrote:[aparently your using it to fetch groceries ? :roll: :lol:
Naaaa... I'm picking up your paycheck.
And Brits wife :wink:
