Gears...and more wider gears....
- Skidmark
Hey there Hoons !!
OK, so fill me in on the wide ratio gear thing.
I'm just a retard, so speak slowly and clearly OK ??
I have a 90 motor. Tranny is WAY too short. I would like more top speed without losing 1st & 2nd's ability to cruise goat trails at a glacial pace....slow is good.
Can I use later year 500 gears for just 3,4 & 5 ??
Lay it out for me if you would.
MAHALO !!
"Skiddy"
P.s. I need a rear 18" wheel complete, or just a 18" rim or a 36 spoke hub w/20mm i.d. bearings for a Excell rim I already have.....
MAHALO !!
"Skiddy"
In your trans you can use any 4th and 5th from 86-01 on your shafts
ask danny graves if he still has that hub without spokes
- Skidmark
So do I just buy the appropriate gears or are the shift forks different etc ??
MANY MANY MAHALO'S !!!
"Skidmark"
Yo, Danny...you go a line on a 36 spoke rear hub ??
"Skidmark"
There are actually 4 individual gears that you replace. Two on the main shaft and two on the intermediate. Just follow the page out of the manual and it'll work out fine. I did it and what a difference!! but then again, I run a 14/45...
ya gotta watch the term "wider", the 98-01 gears physical width is more than previous years, but still fits the cases and mixes with '86+parts. The ratio is "wider" as compared to the close ratio '88-'92 trans.
if you can get a trans for under 180.00 us your still cheaper than buying the 4 gears to do the swap.
I'm going to put only the tall 5th from an '86 trans set into my '88 for a road gear, and keep the lower 4th for still haulin ass in heavy ground
1994 (cheaper than '98) part numbers
4th counter:23471-ML3-670
main:23461-ML3-670
5th counter:23491-ML3-670
main:23481-ML3-670
main:23461-ML3-670
main:23481-ML3-670
http://portland.craigslist.org/clk/mcy/878158318.html
check it out this dude is parting his 00' 500 and he's getting rid of an 18'' er...would that wheel fit a gen 3 250 swingarm no problem?
I made a pair of small axel adjuster blocks for my '02 cr250, and a bushing to slip in the brake, now I can run the 18" rear on the small axel, and swap it from my 500, my 500 extention can use either axel aswell
- Skidmark
Thanks guys for your help and direction....
Yeah, I need a 18" 32 spoke rim only. Mine is coming apart internally.
I "won" a brand new complete 18" rear wheel on E-bay...listed as a CR250/500....and it was PERFECT....except it's a stock DRZ400S wheel (which I also ride...so no great loss there, and the price was right).
I also have a complete set of gold Excel wheels for a late RM250 that won't fit my DRZ. Anyone need RM Excel's??
Anyway, thanks again.
I'm outta here!
"Skiddy"
I'm outta here!
"Skiddy"
What about a real Wide ratio?
I just found a link to a company which is advertising a wide ratio kit. Same 1st and 2nd new 3rd 4th and 5th. Kinda pricey but if you want to play sometimes you have to payhttp://www.madmanengineering.com/wideratio.htm
