Buying Used Stabalizer Question.
- nobrakesbill
I found a used Scotts Stabalizer on Craigslist. Here is a picture. Is that all that I need or is there more to install the unit? The guy wants 250.00 is that a good deal?
'86 CR 500
'97 CR 500
'00 CR 500
'08 CRF 150R
'73 AJS 250 Stormer
'97 CR 500
'00 CR 500
'08 CRF 150R
'73 AJS 250 Stormer
- redrocket190
The gold damper is common to all bikes. This runs around $320...
It is the combination of the post - which you bolt or weld onto the frame - and top handlebar mount which position the damper correctly for any specific application.
These parts run around $140...
I agree with Bob that this is not the first $400 or so to spend on handling. Spring rate and valving for your weight, speed etc. are the priority. Also don't use a damper to overcome chronic set-up problems like headshake. But if you are going to go fast off-road and want an insurance policy against an unexpected hit - these do work.
http://www.scottsperformance.com/
Michael Stiles
2007 Honda CR500R-AF
- teemtrubble
- nobrakesbill
