$125.00 for the rear,its got a 90% Maxxis Cross on it,still has nipples on the outer lugs,the bearings were changed less than a month ago,when my buddy put the new tire on the first time he stomped the brakes the piece the cable hooks to on the hub snapped off,swap it off your hub and its good to go
$100.00 for the front,its got a maybe 70% Bridgestone m402? I think,will come with bearings
make offers on the rest,the forks need seals,the rear shock needs a rebuild,the plastic adjuster on the reservoir was broke off when I got it but could turn with pliers,I recovered the seat last year,the plastics are all usable,the tank has some white spots from sitting outside,easily removed with some sandpaper,the shrouds look kinda ghetto,I just cut up some carbon fibre look sticker and covered them,they're all scratched up underneath,the rads are usable,the left one has a jb weld repair on the bottom from the previous owner but does not leak,the right one has no repairs,could probably straighten out some of the fins but they worked fine,airbox has a few little holes where the midpipe rubs on it but usable,front brake assembly works fine,triples are good,swingarm has one homemade chain adjuster,any questions just ask
so ya I cleaned some of the parts up a bit and took some more pics,I'm gonna drop the price on the rear tire to 100 bucks,its got more scratches then last time I saw it cleaned up,but still very nice,The front is in much better shape,very very nice,The seat was recovered last year,has no rips,the thing that hooks on the tank is worn but still holds on,The kicker just needs a knuckle,the brake pedal is good as well as the pegs,maybe could use a good cleaning
Prices including shipping
Rear Wheel-$100.00
Front Wheel-$100.00
Seat-$30.00
Kicker-$30.00
Pegs-$20.00
Silencer-$30.00
Brake Pedal-$20.00
