Top end questions
Top end questions
I recently bought an aftermarket gasket kit for the 500 (should have gone genuine i know). I am wondering though, should the cylinder base gasket be a metal gasket the same as the head gasket? What do you get in a geniune kit? Also, i gotta get new piston and rings, iv seen a couple of brands like wiesco, vortex and pro x but any suggestions what i should go with for value for money being that they seem to vary in price a bit?
Thanks.
Thanks.
the wiseco gaskets are cometic. I find the cometic topend gasket sets on ebay for like $17 all the time, so I always have an extra. The cometic base gasket is a metal shim style.
- teemtrubble
Should anyone happen to get one of those K&S kits off ebay don't use the base gasket. Its a fiber materal and will leak soon after.
2013 Dodger Charger 5.7 Hemi
http://www.prisonplanet.com
Your Amsoil Customer # 350882
I learned the hard way... have a k&s base gasket blow out on both sides, and had some "boss" main bearings crumble! the balls fell to peices and bounced around and the seals that came with them sucked. as far as K&S goes, the center case and side cover gaskets hold up fine, just the base gasket is too weak and blows out. The k&s seals are junk.100hp honda wrote:most of us been saying that for years. aparently you and mfdb missed the memo . werent you also the one using the $9 ebay crank bearings ? wich reminds me, how they holding up ?
I only use honda bearings and seals now, whichever gaskets I've got for the bottomend, and cometic for the topend
- teemtrubble
Then don't buy their shit Iggy...iggys-amsoil wrote:Oh the ones made in China ? for $32 a pair.
There's a lot of hours on those @ 50:1 and holding up so far. Man I got like 25 races on those 35-40 track practices and who knows how many free rides.
I guess not everything from there is crap. I just don't like supporting them
teemtrubble wrote:Then don't buy their shit Iggy...iggys-amsoil wrote:Oh the ones made in China ? for $32 a pair.
OEM only for me. I find that if you use the friggin TORQUE ADAPTER and TORQUE the jug PROPERLY base gaskets dont blow out. To many people think they have a better "feel" then a torque wrench and are too cheap to buy the $15 Motion pro tool.
http://www.motionpro.com/motorcycle/too ... h_adapter/
Remember to clean and lube any threads you are torq'n to make sure you get even accurate numbers...
BAH! torque wrenches are for pussies!M.F.D.B. wrote:OEM only for me. I find that if you use the friggin TORQUE ADAPTER and TORQUE the jug PROPERLY base gaskets dont blow out. To many people think they have a better "feel" then a torque wrench and are too cheap to buy the $15 Motion pro tool.
the one base gasket I blew out was the result of a combination of a weak gasket and no loc-tite on my studs. Now I loc-tite my cylinder studs and haven't had a problem since. I just like the cometic gasket design.
