coil differences?
smokindodge
coil differences?
Post by smokindodge »
Will the coil from an 88 bolt up to my 99 aluminum chassis without the adapter? I know some of the older ones will but not sure which ones.
ShanMan
Post by ShanMan »
pretty sure the answer is no. The 250 coil (which some claim you can use) is considerably smaller than the stock 500 coil. The adapter I did not only allows you to mount the coil, but it also moves it away from the heat of the jug...FYI.
CR500AC widget maker
a 250 or 125 coil will work fine with your electronics. the '86 was the only coil with the newer bolt pattern, but its also a different resistence
