Well, my buddy blew up his 1991 CR500 and I have acquired the rest of the bike. I have no use for any of this stuff, so I figured I'd offer it up here. Here is what I have:
steel subframe $40.00 <sold>
kicker lever $40.00
Stator and flywheel <sold>
PC Pipe (little tweaked, but worked) $65.00
front wheel assy. (slight wobble, not noticable when riding) <sold>
throttle housing and cable <sold>
complete rear brake system <sold>
Clutch perch/lever and cable $15.00
rear shock/spring assy $65.00
swingarm & shock linkage (probably needs new bearings) $65.00
cylinder head (one fitting has been JB welded, doesn't leak) <sold>
Cylinder (has LA sleeve and is .060 over now. Really needs to be resleeved. Can probably bore to .080 over, but I wouldn't) still available
All costs do not include shipping. I will charge actual shipping costs which should not be bad since we get a discount at my work. I can email pics of all of this stuff if needed. Just email me at DPisarek@comcast.net ! Thanks
DPinDet
1991 Parts left over
"Trees are for traction"
- teemtrubble
tranny gears
Sorry, the whole lower end was sold days after the meltdown.
DPinDet
DPinDet
- teemtrubble
1991 parts left over
Here is what I have left from a parted out 1991 steelie. I only have A/F's , so this stuff is of no use to me. I can email pics upon request. Make offer and it's yours. No reasonalbe offer refused. Thanks
Rear shock and spring assy.
swingarm
swingarm linkage (can use new bearings)
stock reed cage and intake boot
carb boot
swingarm bolt
clutch perch and handle
None of this stuff is terribly big, so shipping should not be bad. Thanks
DPinDet
swingarm
carb boot
swingarm bolt
DPinDet
