what are the hillclimbers running?
racer786
Post by racer786 »
just curious what the hillclimber guys are running for coolant in there 4cylinders...ive noticed some bikes with coolant lines and no radiators(evans?)bikes with the engine blocks full and blocked off (evans again?) and ive seen no radiators on the nitro bikes for obvious reasons...just curious what would be a good setup to run on a 600 4 cylinder running 100 octane and a 30 shot of Nos
"The only thing scarier than ignorance is the illusion of knowledge"
Slomo
Post by Slomo »
I welded up a 12 oz. nitrous bottle to use as the reservoir and run a closed loop system with a 50-50 mix of plain old antifreeze and distilled water.
racer786
Post by racer786 »
sounds good to me except i think i am going to use a miller chill aluminum bottle i got in vegas its pretty sweet looking?
Post by M.F.D.B. »
slomas wrote:I welded up a 12 oz. nitrous bottle to use as the reservoir and run a closed loop system with a 50-50 mix of plain old antifreeze and distilled water.
Ya, like you have any climb experience, arm chair cow boy... :lmao:
