Can't get the Turbo to fit.....on my 02 AF
pimp559
Post by pimp559 »
I got a new turbo paddle that won't fit with out rubbing on the airbox mud flap. If I pull the wheel back the chain is too short and not long enough to run an extra link and two masters. I took the mudd flap off to run at Pismo the weekend after next but don't like the idea of a sand bath on the back off my motor. Anybody had this problem, what did you do?
they all have this problem, get a shock sock and leave the flap off when the paddle is on.
yep
teemtrubble wrote:yep
X2
redrocket190
Post by redrocket190 »
Same here. Glad I took the air box flap off because on the move the paddle grew big enough to kiss the swing arm. Couldn't get a Shock Sock, but having seen these on two other bikes, it's on the shopping list. I ran my chain a little loose for the reason you found. Next time, I might try a 15T counter shaft sprocket just to take up a little slack. You could do the same at the rear, but it'll cost you for a rear sprocket.
Michael Stiles
2007 Honda CR500R-AF
I've used just a plain sock over the shock and that worked out fine...
you guys are amatuers :roll: . i never had that problem with hooker paddle. maybe i added 1 link but cant remeber how i did it or maybe hooker is different size than a turbo
the king turbo paddles hit even when all the way back on my gen-1. didn;t have that problem on my '86 though.
ya i didnt think about that its a AF and the swingarm is obviously different
pimp559
Post by pimp559 »
I let as much air out as possible and that helped a little but still had to ditch the flap. I even custom shaved a little off the cups for some of the longer paddles. I also noticed the chain had been slapping the dirt tire a little and I know the tension was correct. I'm wondering if I need to flip the counter sprocket over for tracking purposes?
why are you putting a 8 blade paddle on a 500... you just want to sit there and spin the tire all day?? get something with some bite 10cup minimum on a 500 :D
pimp559
Post by pimp559 »
ISBB wrote:why are you putting a 8 blade paddle on a 500... you just want to sit there and spin the tire all day?? get something with some bite 10cup minimum on a 500 :D
It was free, and yes I miss my old 10 paddle. :D
if i wasnt selling my spare rim i would give you the 10 cupper off of it :D
X2
X3
my sicky gnar gnars gen-1 runs a beat to hell 8-puck and hooks just fine! :cool:
infact, it sinks, then grabs, so it really grabs a little too well, I might go up to a 12-puck to get more float out of it and thus a little more controlable wheel spin.
pimp559
Post by pimp559 »
ISBB wrote:if i wasnt selling my spare rim i would give you the 10 cupper off of it :D
Why don't you just tease me a little :(
glen howell
Post by glen howell »
You can saw the ends out on the swing arm, Or you can use a 520 half link we have the half links $6.25 Glen (TEAM GSS) NAHA #42
pimp559
Post by pimp559 »
Didn't know you could still get half links, I'll definetly call you if this doesn't work.
