Brake pedal issue
- eyesky2002
Brake pedal issue
Just installed a 03 CRF450 brake pedal on my 03 CRF450 frame, fits tight against the motor and hits the case Mind you I do not have my master cylinder (in the mail) yet, so maybe it is just sitting high and I am panicking Any ideas??? Here are a few pics...
MXMotoworx.com
2003 Honda CR500AF
MXMotoworx.com
2003 Honda CR500AF
- teemtrubble
- eyesky2002
- eyesky2002
- teemtrubble
- Wheelie-Gene
Something I did to keep from scratching my clutch cover was to use a teflon washer between my brake pedal and frame. OD 27mm, ID 6mm x 2mm thick. Just thick enough to prevent metal to metal contact in any circumstance but a crash.
I've seen covers begin to leak because vibration and normal lever operation wore a hole through the aluminum.
We don't have the same cover, but yours appears to be positioned close to mine. I moved mine up when I was able to push it out.
