Not a 500 ? but still very important
How long should it take a brand new 12v waterpump to start actually pushing water to the faucets in a motorhome? I can hear it running and it is pushing air but it just spits a little water. I was thinking it was because I had the front of the MH higher than the rear but I put it on more level ground but still no water after about a minute or two. Water tank is about half to 2/3 full. I need some advice fellas. If I don't get this thing pumping water the wifey won't go to Pismo and Me and the boy will have to tent it!
Her B-Day is just before we leave so this was supposed to be her B-day present.
HELP!!!!!!!!!!!!!!!!!!!
eyesky2002
Post by eyesky2002 »
Assuming its not leaking out somewhere before it reaches your tap, I would guess the pump is bad. Can you get to the pump and see if it is pushing any pressure out of it? Another possibility is the inlet could be plugged, maybe blow some air from the pump back into the tank.
MXMotoworx.com
2003 Honda CR500AF
CR480R
Post by CR480R »
Check for an air leak on the inlet side of the pump...
Current bikes- 1983 CR480
Former bike- 1990 CR500
FIXED!!!!!!!!!!!!!!!!!!!!!!!!
You nailed it !! It was a little filter that was hidden under the refrig that had came loose and was just sucking air!
Pismo here we come!!!!!
Good job brother!
