All you ever wanted to know about swappin' parts year 2 year
Courtesy "Roostius_Maximus".....
Ok, its not a manual, but I've worked outa bunch of diagrams that explain the misconceptions of the engine, and Interchangeability,
Image[/i]
kball1313
Post by kball1313 »
awesome thread! Thanks front BC
Joshwfl
Post by Joshwfl »
Very, very nice!
dahondaboy
Post by dahondaboy »
hopefully this will prevent someone else from losing money on the wrong parts. awesome job!
redrocket190
Post by redrocket190 »
http://rapidshare.com/files/107737872/H ... _Years.pdf
Someone let me know if they can download this OK. It is a PDF document of the diagrams Bob posted above.
Michael Stiles
2007 Honda CR500R-AF
Uzi
Post by Uzi »
Great thread :cool:
1982 XR200
1985 CR500 86' Motor
1990 CR500 85' Motor
2000 CR250
nice work
hey, nice to see this is helping some hoons, I've got more some are crappy. Anybody got requests I'll work on it!
Last edited by Roostius_Maximus on September 27th, 2008, 9:23 am, edited 1 time in total.
I've done updates to these...
Last edited by Roostius_Maximus on October 27th, 2008, 6:55 am, edited 8 times in total.
kball1313
cases
Post by kball1313 »
What about the main cases? Seems like you da man to ask. Any differences after 89?
case question
only the paint changed
B440
Post by B440 »
I've been staring at the first pic showing the clutch covers. The wording makes me think that an 87 clutch cover will fit on an 86 case. Is this true?
I will be a pig in shit if it is.
kkvslayer
Post by kkvslayer »
B440 wrote:I've been staring at the first pic showing the clutch covers. The wording makes me think that an 87 clutch cover will fit on an 86 case. Is this true?
yup,bolt on and go
1994 Heartless CR500R
1986 KX500
yup,bolt on and go
X2
shedding some light on the case question, specs to follow, but these should help for now. Chevk out how even til '88 they machined the case the same as an '86, but gave it the taller deck, theres windage room cast in it that was filled in newer cases.
88 lh
91 lh
88 rl
91 rh
dahondaboy
I am currently machining out my 88 case to accept a 2001 cylinder, it really isnt that big of job, i will have to put longer studs in for the base but other than that it should be done late tomorrow, here highlighted in red are the areas that have to be milled out. also the edges of the sleeve have to be rounded a little.
In attempting to remove the studs from a junk case i stripped the threads, now scared to wreck good cases i use a 1" x 10" endmill, reach past the jug and top the boss a the back to match the '86-'88 cylinders, i also cut the sleeve down so i can use it on cases that have been previously assembled without having been bored. There is enough thread on the 89-01 rear studs to use the old jug height if i need to switch it
dahondaboy
when you say you cut the sleeve down, about how much do you cut and do you mean the length or the diameter of the sleeve cause i thought about just milling the sleeve till it was the same as the 88 but it looked like it would be stronger if i just milled out the case and left the sleeve thick .
i left the lenght, and cut the od by using a boring head with the tool to the inside, made it fit a case that was assembled, but needed a jug
dahondaboy
here it is. After taking 3.5mm off each side its a perfect fit with the 01 jug
the front base studs will work as is but the rear two are flush with the top of the hole. so now i guess i gotta order some studs for a 01 case.
this mod was tottally worth it though as this jug is a std. bore :cool: and newer jugs are way easier to find than the 88's. i will post better pics after its a little purtier.
as i mentioned, i'd cut down the cyl instead of trying to remove the case studs, the ones i tried in junk cases stripped the threads from the case. I'd cut the back of the jug down and it'd work on either length stud
dahondaboy
I couldnt find a way on the mill to cut the flanges down without cutting into the water jacket i dont have any small bits , so i broke out the flex shaft and used a dremel cutting tooth bit and it seemed to work great.
that'll work huh
BigSteve
Post by BigSteve »
What about the change in port timing by putting the late cyl on the early case? Are they reasonably close to the same IO-IC and EO-EC?
