pwk over rev?
aloha450x
pwk over rev?
Post by aloha450x »
i was told this is what the thingy is for. has anyone seen it before and how in the fuck does it wor and what is it's purpose. i got the carb off ebay a while back and got a good deal on it. it's almost brand new pwk 39. the boot side was turned which made it easier for the stock 450 boot to go on. thats mainly why i bought it. i thought i would worrk about ther "over rev tingy" later. oh yeah why the float bowl things. they go from one side to the other.
Its not a 39mm PWK, those dont have the venting system as shown here.
Do you see the vanes on the upstream side... as shown in the photo?
that thing on the housing is an adjustable powerjet... good for drags and SM, no need on trails or MX
If you want to know more do a search on "powerjet"s because I've been going off about this for a year
aloha450x
Post by aloha450x »
it says pwk on the side. ill take another pic later today. i know its not a airstiker. and thanks danny
The only non "Airstriker" quad vent PWK I know of is the 36mm version.
I wonder if someone drilled / tapped the vents themselves?
little hex head on the nipple in the top, I think you are right Bob.
aloha450x
Post by aloha450x »
what about the hexhead? and what vents are you guys talking about? quad vent?
fastkart
Post by fastkart »
Looks alot like the 38 A/S I have in my hand right now.
aloha450x
Post by aloha450x »
its not a a/s it dosent have the wings
Then its a 36mm, or a home made quad vent.
home made quad vent. like I said, the hex heads below the hoses on the upper vents show it was drilled and tapped.
aloha450x
Post by aloha450x »
is that bad that it is homedone?
aloha450x
Post by aloha450x »
aloha450x
Post by aloha450x »
The two vents pointing "UP" were added ..... no biggie.... At least you know what you have now.
aloha450x
Post by aloha450x »
you mean on either side of the choke on the top? and what is the reason behind the goofy floatbowl action. haha
thats the fuel supply for the powerjet. I say run the SOB, but I sure hope you know a little about jetting...
aloha450x
Post by aloha450x »
learing what ican from you hoons.
I'd plug it ..... Get the bike running sweet first, then dick around with it later...
aloha450x
Post by aloha450x »
where do i plug?
aloha450x wrote:where do i plug?
Turn the little knob clockwise to shut it off.
naaa, I'd put a 140-150 main in it (%20 reduction) then turn it way out, the first time you get on it and hold it, it should blubber, keep turning it in until it stops blubbering and you'll be haulin ballz! :wink:
fastkart
Post by fastkart »
I believe my GSS motor has a 140-145 in the main plus the power jet.
Where could I get ahold of one of those adjustable powerjets? would it be a direct replacement for the mikuni I have now? Another worry... it won't adjust itself with vibes, etc will it?
aloha450x
Post by aloha450x »
whee can I get a good read on this ? and it hasa clip so it won't mmove
glen howell
Post by glen howell »
GSS ALcohol Carb. PWK 39 bored to 41mm
Image[/img]
