Fork oil capacity, weight, brand
I need to get my fork seals done. Does anyone know the capactiy for oil, what weight, and a suggestion on brand of oil I need for a '94?
2013 Dodger Charger 5.7 Hemi
http://www.prisonplanet.com
Your Amsoil Customer # 350882
- redrocket190
This is what the manual says....(no more no less)
Minimum - 534 cc or 143mm height
Stock - 567 cc or 110mm height
Maximum - 576 cc or 101mm height
Pro Honda SS-7M recommended which I assume is 7-weight
...and I recommend AMS-Oil because its makes Service Hondas easier to start.
Michael Stiles
2007 Honda CR500R-AF
- redrocket190
- teemtrubble
Yes they do make a 10W.Crow500 wrote:They have a warehouse operation up Lamb from Craig. Its right near my work. I'll have to stop in and see what I can find out.dannygraves wrote:I'm sure they do.
4545 Lamb Blvd. #C however if your not a dealer they won't sell it to you from there. Sorry it's just the way they do business.
- teemtrubble
- redrocket190
Try this....Crow500 wrote:I checked my PMs, but didn't find anything thing about a manual.redrocket190 wrote:...the service manual I have is '92-'94. I'll get it to you (both) by PM and you can check it out.
http://rapidshare.com/files/121457170/1 ... Manual.pdf
Big file, I'm afraid.
...from the RaceTech web site:
A 260lb rider doing trail/enduro riding needs a 0.5 kg/mm fork spring (stock is .392) and a 6.2 kg/mm shock spring (5.2 kg/mm stock). Don't confuse using a heavier weight oil as a substitute for the correct spring rate. Raising the oil height will reduce bottoming out.
Michael Stiles
- teemtrubble
here is a link I have on my hosting space
http://pho.sunrisehvac.com/500/manual/92-96CR500R.pdf
as the link says, '92-'96 I have a '85-'89 on in that folder too.
