vertex...0.0????
dahondaboy
vertex...0.0????
Post by dahondaboy »
what is the piston clearance supposed to be on a vertex piston? it came with no instructions. same as wiseco or is cast different?
Same as oem, somewhere between 0.002" to 0.0025", depending on how accurate your machine shop is....
http://www.bannedcr500riders.com/board/ ... t=cylinder
Heres a link showing my Vertex
ou812
Post by ou812 »
If I remember correctly the instructions with my vertex said 28 for 500cc applications.
dahondaboy
ive got it at 0.003 rigt now but feels way too tight by hand, i think ill open it up to 12- 15 what do you think? too much?
Mine was 0.00225" 4 years ago.
No blow by.
No squeek.
No issues.
Lots of Duning..... pinned.
Gotta' love it!
ou812
Post by ou812 »
ya but you run good oil and know jetting, the factory will alway quote a safe for all number
Factory spec is 0.0027" to 0.0035"
dahondaboy wrote:ive got it at 0.003 rigt now ...what do you think?
Run it.
Run it.
X2
kanecr50094
Post by kanecr50094 »
do the bridge if that tight
THE BRIDGE SHOULD ALWAYS BE DONE REGARDLESS!
.003 is bitchen run it already!
dahondaboy
i already relieved the bridge, i have 9 days till widowmaker and dont have it together yet. my crank seals and oil seals just came in tonite so i can have the thing ready to bolt in by this time tomorrow. i just got my swingarm back from being extended and it is nice! 65-3/4 " axle to axle fully extended. ill post pics when i have it all together. its at the last bore so i need it to just last 2 or three good hard runs, then it gets a glen'ed jug.
