560 kit on ebay
I actually think thats a pretty good price considering what you are getting and the ammount of work to put a kit like that together. DeWayne charges only a couple hundred less to have a stock jug resleaved with aluminum, ported, then nikasiled.
Slow old Fart
If calvin would finish the saber it is a better value than that. The 560 kit should produce a good bit more torque but HP Is ?able. When you go bigger they do not like to turn as many R's so there goes your HP #s.
I bett that kit with a FMF Narly would ROCK! I mean lowend and midrange from hell. Great with a Z Start I bett?
hogwash! calvins stuff would stomp that 560 in the ground. and the saber is proven itself time and time again on about every sand dune and track in the country (single cylinder KOTH, glamis 2004). in fact i think packards saber has the single cylinder record right now in the 300ft.....i havent heard anybody say they've even seen the 560 in action, no youtube videos, not word of it from other forums...NOTHINGSlow old Fart wrote:If calvin would finish the saber it is a better value than that. The 560 kit should produce a good bit more torque but HP Is ?able. When you go bigger they do not like to turn as many R's so there goes your HP #s.
Slow old Fart
I don't think you understood what I was saying, the 560 has the potential to make more torque than the saber dowlow and in the midrange so it could fessably be a great torque monster. a FMF narly is designed to make peak power early and in conjunction with this cylinder you may have a 1 or 2 speed racer with no problem.100hp honda wrote:hogwash! calvins stuff would stomp that 560 in the ground. and the saber is proven itself time and time again on about every sand dune and track in the country (single cylinder KOTH, glamis 2004). in fact i think packards saber has the single cylinder record right now in the 300ft.....i havent heard anybody say they've even seen the 560 in action, no youtube videos, not word of it from other forums...NOTHINGSlow old Fart wrote:If calvin would finish the saber it is a better value than that. The 560 kit should produce a good bit more torque but HP Is ?able. When you go bigger they do not like to turn as many R's so there goes your HP #s.
The Saber is vastly superior in HP I am sure, I think you need to slow down sucken in that slop from the hog troth it's startin to back up on yaa.
