they say the 4043 is better for 6000 series, but 5056 is more MIG feeder friendly. I can't find a spooler gun for my welder, but read about a few guys welding aluminum using the standard feeder. Gonna buy my regulator and an empty tank tomorrow. There is a place called airgas that my work buys all their gas from, so I can get a deal. Should I do all argon, or an argon hydrogen mix? co2 mix?
I'm only looking to use this to tack and for exhaust hangers and other non stuctural welds. I figure what I spend setting myself up to mig AL is less than I will pay the welder to do all the little stuff and I will be setup to fix future cracked subframes and broken exhaust mounts, etc.
welding experts! 4043 or 5056 and what gas?
4043 is better for mig using the standard feeder, but you need to use a plastic liner if you use the standard feeder. plus it won't contaminate the wire.
straight argon or argon/helium mix is what you need, an argon/co2 mix won't work. one thing you need to do with the standard feeder, is change out the drive roller to one that is smooth, most are a serrated roller to grip better, but it'll score the aluminum and will cause particules to clog the liner. i couldn't find one for my little mig, so i just turned the tention way down. it was better, but didn't stop it.
TJ
2005 cr500af
2008 300XC/w
2005 cr500af
2008 300XC/w
ok, I picked up all the stuff I need today (its nice working for a construction company
I got a nice harris regulator and hose for FREE, and paid $101 for a tank already filled and a roll of wire. I'm good to go. Now my question is about wire diameter.
My MIG has tips for .023, .030 and .035
I just grabed the .035, but before I open it, I was wondering if another size would be better...
From what I've read, the smaller the better unless the material is really thick and since I have a pretty weak welder I'm wondering if thinner would be better to keep the heat down and the load on the welder down. But I also wonder with using the built in feeder if the thinner wire will be more likely to have feeding issues. I haven't opened it yet, so I could take it back.
Thanks
Thanks
- teemtrubble
I prefer 4043 wire and no bigger than .030 wire for those smaller welders and Argon/Helium 25%
