Gen 1 AF kit needed URGENTLY
KTM Killer
Post by KTM Killer »
Hi guys
Alex here from Tanzania East Africa , Im really keen to own the first CR500AF in Africa, but nobody can help me with a kit.
If there is anyone out there that can help me, please email me at: alex.oelofse@gmail.com
Cheers
honestly, if you can find someone capable of doing the welding, they can probably mock up something that would work. like a 1" cylinder shape with a side cut flat could be used for the franot mounts, some stacked washers can be used for the spacers, use the 250 coil so you won't need a coil adaptor, then the headstay will be the worst part. Find some 1/4" aluminum plate and cut the front half and back half of the headstay, then make a peice that will go in the middle, then drill for 2 bolts to go through the middle. I was planning on doing all that before we made the kits, but it really isn't cost effective to make 1 more kit. Plus I told Shanman I'd only do 1 run of them. It took us like 8 months to sell off 17 kits.
kball1313
gen 1 kit
Post by kball1313 »
I have a pair of eng. mounts I bought from Danny that won't work on my Gen2. I'd gladly ship them if you want. The rest is cake.
