wont idle w/o choke after carb clean
yoshirocks702
Post by yoshirocks702 »
hey guys i was cleaning my carb the other day just to help the bike cold start a little easier i think i succeeded with that because it started on the first kick but now it wont idle w/o the choke on i set the idle mixture screw to 1-1/2 and the idle speed screw to 6 out (what the manual calls for) i opened the carb again to look at the pilot jet and it looks clean (i can see through it) im baffled at this could it be something with the choke assembly or the choke circut in the carb? thanks for the help :D
bigjay
Post by bigjay »
open the choke all the way, those things crank out a ton of turns, if you can open it all the way and it still wont idle then you have air/fuel issues and well go from there, also make sure you got the boot back on all the way ( DOH ive done it before).
Jay
I break stuff
yoshirocks702
thanks you were right the idle had to be turned up :D
bigjay
Post by bigjay »
sweeet :D
Jay
I break stuff
