Mad Dog
Posts: 604 Joined: June 27th, 2007, 2:16 pm Last active:
Post
by Mad Dog » April 3rd, 2008, 4:45 pm
I just ordered up some Evans NPG+. I was curious who runs what?
Watter Wetter
Engine Ice
Evans
Coolanol
50/50 antifreeze
Distilled water
Other
If someone wants to turn this into a poll. That's fine with me.
Post
by britincali » April 3rd, 2008, 5:03 pm
Pre-mixed cheapo coolant for me.
Uzi
Posts: 218 Joined: June 21st, 2007, 9:10 pm Last active:
Post
by Uzi » April 3rd, 2008, 5:44 pm
Engine Ice
1982 XR200
1985 CR500 86' Motor
1990 CR500 85' Motor
2000 CR250
Post
by lewisclan » April 3rd, 2008, 6:42 pm
EVANS period.
I have alot of bikes xrs crs & fricken bad ass crs Evans is where its at .
keep in mind that if you bike runs hot it will still run hot with evans it just wont boil over . so if you are a rider you will know your hot and will shut it down to cool off with out boiling all your shit out to tell ya its fricken hot ass hole . so I guess Evans is only for rides who would know the diff.
its all about the love
Post
by iggys-amsoil » April 3rd, 2008, 7:07 pm
Amsoil Propylene Glycol Antifreeze, 50/50 mix and a 1.6 cap.
fastkart
Posts: 645 Joined: November 20th, 2007, 10:06 am Last active:
Post
by fastkart » April 3rd, 2008, 9:07 pm
50/50 green antifreeze.
ou812
Posts: 794 Joined: June 22nd, 2007, 12:41 pm Last active:
Post
by ou812 » April 3rd, 2008, 9:30 pm
1.6 cap.
Wow dude thats living on the edge.
Post
by dannygraves » April 3rd, 2008, 9:31 pm
50/50 preston premixed. used to run engine ice before the a/f, but since I converted, it stays cool on regular 50/50 with an overflow
Post
by iggys-amsoil » April 3rd, 2008, 9:36 pm
ou812 wrote: 1.6 cap.
Not really, being on the same track with a few top named Pros, now thats living on the edge. Or is that "Living the Dream"?
Posts: 15404 Joined: May 31st, 2007, 6:39 pm Last active:
Post
by AlisoBob » April 3rd, 2008, 11:10 pm
90% distilled water, 10% water wetter.
Post
by lewisclan » April 4th, 2008, 4:30 am
AlisoBob wrote: 90% distilled water, 10% water wetter.
lewisclan on April 4th, 2008, 4:33 am, edited 1 time in total.
Post
by lewisclan » April 4th, 2008, 4:33 am
No need to run more than a stock cap with evans it wont expand . you can pull the cap at any temp. and check the level.
MICK
Posts: 811 Joined: June 14th, 2007, 3:43 pm Last active:
Post
by MICK » April 4th, 2008, 5:24 am
and a 1.6 cap.
Posts: 2628 Joined: July 2nd, 2007, 8:48 am Last active:
Post
by hoofarted » April 4th, 2008, 7:25 am
MICK wrote: AlisoBob wrote: 90% distilled water, 10% water wetter.
and a 1.6 cap.
I thought u needed a least a little coolant with water wetter...I know its supposed to work better with the most water, but...?
Post
by britincali » April 4th, 2008, 7:43 am
Water conducts heat better than antifreeze, the best 'coolant' is what bobs running.
MICK
Post
by MICK » April 4th, 2008, 7:43 am
Water Wetter provides all the lubrication and corrosion protection you need. It works best with one ounce of pink stuff per quart of H2O. Which is about all the 500 holds anyways.
*IF* you use Water Wetter in your truck or bike during the winter you should use at least 15% antifreeze for protection. But if you live south of the mason dixon line like I do that doesn't really apply.
Post
by hoofarted » April 4th, 2008, 7:44 am
Ah -I've run it before in my old Scirocco and it did work well...but I had 60% coolant in that.
Posts: 2960 Joined: June 1st, 2007, 11:27 am Last active:
Post
by M.F.D.B. » April 4th, 2008, 10:36 am
Water Wetter tells you on the bottle the less "coolant" the better it works. But if you live in a cold climate thats not an option...
Im not sold on the Evans yet. After all it is an "oil", so even if it wont boil over, I still worry about its thermal characteristics (how long does it take for your deep fryer to heat up and cool down??)...
Mad Dog
Post
by Mad Dog » April 4th, 2008, 1:30 pm
lewisclan wrote: EVANS period.
It is all about the love.
Jay, have ever had to shut down because you were running too hot?
Post
by dannygraves » April 4th, 2008, 1:36 pm
ya, my bike runs like a coke whore with an 8-ball and I don't have any heat issues with my prestone $5/gal stuff, so I'm keeping it!
Post
by M.F.D.B. » April 4th, 2008, 4:22 pm
Honda 50/50 all the way baby...Its $5 a quart, so it MUST be awesome shit!!
Post
by dannygraves » April 4th, 2008, 4:28 pm
thats what I used to run, but the closest honda stealership in carter, and I'm not driving that far for coolant!
Post
by M.F.D.B. » April 4th, 2008, 4:30 pm
dannygraves wrote: thats what I used to run, but the closest honda stealership in carter, and I'm not driving that far for coolant!
Cycle gear and Sams among others dood...or do what everyone else does and use my shit...
aloha450x
Posts: 874 Joined: December 8th, 2007, 12:38 am Last active:
Post
by aloha450x » April 4th, 2008, 4:43 pm
im gonna run the same as bob. I have ran waterwetter in every motorcycle I have owned. zero problems. I love the stuff and the anti corrosive propertys for aluminum are a bonus. one bottle last a loooooong time.
