forged vs cast
forged vs cast
if i had my way my machine would have forged or billet crank, rod and piston- unfortunatly that aint a option for me....hell i would even like billet cases but that aint gonna happen either. i want to get a discussion going on everybodies preferences
Do you want a discusion or an argument? I say cast pistons rule. You can keep your siezcos, I prefer to ride my bike, not rebuild it every other ride. :D Next.
fastkart
Post by fastkart »
Wiseco, all the way. Never seized one or had any trouble that was piston related while running one.
I want :
"0" time FACTORY ASSEMBLED Stock CR500 Bottom end with a Eric Gorr " Mo Betta'" jug. The only changes would be 2x sealing area on the base gasket at the transfer ports.
Period.
You can keep all your aftermarket junk...
Xylicon
Post by Xylicon »
I like my Wisecos, never had a problem, :wink:
97 CR500, 94 CR250, 87 CR125
Wisecos and Blendzall for me..... :lol: :lol: :lol:
heres the run down so far:
wiseco
1- 100hp honda
2- fastkart
3- xylicon
4- Pstofers
finally saw the light and converted to wiseco
1- brit
2- danny graves
3- MFDB
cast PRO-X
1- aliso bob
2- ported&polished
ou812
Post by ou812 »
I'm still not sure, I've always been for cast ,but on my latest I've gone wiesco at 32, bored with a plate, need more time on it but all is good so far but it's still smoken rich, ain't had time to jet yet. Time will tell.
hey man, I've always run wiseco all the way mang!!! seized my fair share.. :oops: but, hell, I used to run wisecos in my CAR! :D
bigjay
Post by bigjay »
i just want my next piston to not do this EVER :evil:
thats my only wiseco experience except for the one that was in my yamahaha 490 back in high school which had about a million hours on it and still ran strong. what are the what pro's and con's to each type?
Jay
I break stuff
you can run tighter tolerances in a cast because they expand less than the forged, forged are stronger.
If you want an all stock bike and want to be able to fire it up cold and hop on wihtout hearing any piston slap, then cast is the way to go. If you want to build a hot rod bike and pay close attention to your tuning and temps, forged is the way to go.
hill climb or dunes riding, I would think %100 forged. Trail, MX, cast
bigjay
Post by bigjay »
are wiseco's forged and pro-x cast?
Jay
I break stuff
fastkart
Post by fastkart »
bigjay wrote:are wiseco's forged and pro-x cast?
Correct.
bigjay wrote:i just want my next piston to not do this EVER
I could be wrong, but that looks like a Wiseco to me. A stock piston will crack, but a forged unit will blow up and destroy your motor, oh, I see you already found that out. :lol:
Now lets see the first rebuild I did personally was a 1987 YZ490 and in that motor I used a ........
wiseco!
I have always been a fan of forged, the only time Ive installed a cast piston is when I rebuilt the bone stock 87 motor in the AF.
I still marvel at that picture Jay. The only dif b/t mine and that is mine was a stock cast and it has a crack 3/4 across the top of the crown. :shock:
Used Wiseco for years and some @ 100:1 mix in the 250 3 wheeler.
100hp honda wrote:heres the run down so far:
wiseco
1- 100hp honda
2- fastkart
3- xylicon
4- Pstofers
1- brit
2- danny graves
3- MFDB
cast PRO-X
1- aliso bob
2- ported&polished
Add me to the cast list :cool:
MICK
Post by MICK »
I can easily go either way. Used nothing but OEM pistons in my KX500. Growing up I was also under the impression Wiseco pistons were junk, just a cheaper option to an OEM piece. My AF is the first bike I've used a Wiseco in. And to this point I am very pleased with it, it seems my feelings towards them couldn't be further from the truth. Honda puts their cast piston in that sleeve with .07 clearance. I put the Wiseco in with .03 as per instructions. Less than half the clearance of the stock cast piston!
I don't think it matters as much what kind of piston you use, cast or forged, as much as it does how well you're sleeve has been machined to accept that piston. 100% of failures I've seen were operator error or a sorry ass bore job.
If I had to choose one or the other the lighter forged Wiseco would get my vote.
MICK wrote: Honda puts their cast piston in that sleeve with .07 clearance.
"Ah..... Thats a big negative Ghostrider..."
Thats .07MM.....
or 0.0025"
NO piston is running 1/2 that...
Cast makes more power too, by the way.
:lmao: :lmao: :lmao:
MICK
Post by MICK »
AlisoBob wrote: Thats .07MM.....
What the hell did you think I was talking about?? .07 yards? I say again Honda's original clearance is .07 or .0027 whichever unit of measurement you prefer.
Bob you're a goofy old fart. I am interested how a cast piece makes more power though.
I'm listening :eatdrink:
EDIT: Holly shit I just realized something that you said Bob. Wiseco's recommends .03 in. Yes I doubt any piston can operate with less than that. I stand corrected.
And I have a feeling you're going to say a cast piston makes more power because you can run them snugger in the bore. But a forged piston is so much lighter I think it about evens those gains.
hes probably going to say that because of tighter clearance, there is less blowby and less power loss to piston rock. Last time I had my wiseco out it showed 0 signs of blowby and is still a bear to kick. If a cast piston does make more power it is marginal at best, I prefer the insurance of a stronger piston myself..
dannygraves wrote:hes probably going to say that because of tighter clearance, there is less blowby and less power loss to piston rock.
Bingo Danny.... good work.
Dont forget heat reflection ( cast doesnt conduct heat as well). Forged grow in EVERY direction. This means the wrist pin hole and ring lands grow too. The cylinder walls of forged piston motor look pretty thrashed for the most part. Cast piston motors are silky smooth...
This is my bike, 3 year old bore
http://www.bannedcr500riders.com/board/ ... php?t=1629
You want the rings as square in the bore, and as tightly sealed to the piston and cylinder as possible. Cast is the hands down winner in this regard.
it all comes down to application, if I had a bone stock bike that I only hit the trails or track on, it would run a cast piston fo sho, but since I hit the dunes... its forged for me all the way!
Why make an exception for the dunes?
N20 Yes
Land Speed Record Attempt Yes
CH3NO2 Hell Yes!
Otherwise, Cast is fine.
