TMX Mikuni???
4Z
TMX Mikuni???
Post by 4Z »
Getting stuff moved around in shop in prep for my frame to come back from Teem Trubble, I noticed that the carb off my donar '03 125 is a TMX Mik that (best I can tell) a 40mm carb with enough meet to broe out to MAYBE 42mm. I have taken the TM out to 42 before many times, but before I strip it down and chuck it up.........
Has anyone ran one of these on a hundy?
TIA
good carb, but only came in a 38mm, its a taper bore I believe, you have to measure as close to the slide as possible with a bore gauge. The part where the boot mounts should be like 43mm, I wouldn't cut too thin. it would run well with some jetting work as is though.
4Z
Post by 4Z »
Thanks Danny, you are correct, I let the carb go with the motor (sold it on ebay this weekend).
So back to original plan, PWK bored with a clippard powerjet.
