Ignitions S/H and others
So being AJ is onboard to give some input, I'd like to put this out there for all to comment on. IMO the current S/H ingition was designed around the idea of making a unit that would produce trackable somewhat tamer power for MX use.
IMO and lets get lots of input, I would like to see a unit gear toward maximum power with a flywheel of the exact same weight/ spec as the OEM unit and just have the ability to bolt on extra weight for trail riding. Maybe also a up grade unit with a on the fly switch for dual curve to switch from trackable to all out power.
Is that something SH could look at selling in the Future? because that is something that would intrest me.
Slow old Fart
I have looked into this in the past and from what I found you make a programmable set up and do it your self on your lap top,
The most powerful setup I could find at the time was by MSD and FTZ was using it for their midget cars, they did not make for a 500 it was for a 250 but could be modified with little problem.
It was battery operated but that is not a problem you just make a simple charging system.
- redrocket190
http://www.vortex-performance.com.au/
10 maps from Vortex
2 maps available via handlebar switch
Available maps selected on box
Software tools to program the maps at your leisure
10 maps from Vortex
Last edited by redrocket190 on February 27th, 2008, 1:35 pm, edited 1 time in total.
Michael Stiles
2007 Honda CR500R-AF
- redrocket190
IMO you only need 3 maps and a decent charge circuit (150w+)
1. For slow ST trail riding where traction is an issue
2. Bone stock
3. All out screamer
If at all possible I would keep the flywheel weight the same as stock or lighter with the ability to add weights if wanted.
With a switch on the bars that would be an awsome setup.
2. Bone stock
3. All out screamer
Slow old Fart
Re: Ignitions S/H and others
I want to here more about the way you rip on those aluma tub's because they ride like a brick.ou812 wrote:So being AJ is onboard to give some input, I'd like to put this out there for all to comment on. IMO the current S/H ingition was designed around the idea of making a unit that would produce trackable somewhat tamer power for MX use.
That was a good post, when I built one back in 2002 I said gee there is something not quite right about this and everybody said suck it up sissy and ride!
I'm lost....Slow old Fart wrote: I want to here more about the way you rip on those aluma tub's because they ride like a brick.
What does the SH ignition have anything to do with the Aluminum bikes??
And what was wrong with your 2002 build ??
Slow old Fart
if you have do not know these bikes are ridid as hell. the design has no flex at the head stay.TYSTYX wrote:I'm lost....Slow old Fart wrote: I want to here more about the way you rip on those aluma tub's because they ride like a brick.
812 made a post in another thread about the way the aluma tubs suffer in some ways because how rigid they are and agent 812 did not respond back so I am hounding him here to explain how talented he his on a motard!
Slow Old Fart...do as TYSTYX's avatar says.Slow old Fart wrote:if you have do not know these bikes are ridid as hell. the design has no flex at the head stay.TYSTYX wrote:I'm lost....Slow old Fart wrote: I want to here more about the way you rip on those aluma tub's because they ride like a brick.
Slow old Fart
The idiot in the avatar has a bigger mouth than me, and I did not think that was possible.TYSTYX wrote:I'm lost....Slow old Fart wrote: I want to here more about the way you rip on those aluma tub's because they ride like a brick.
