I just helped my bud Krush install his Moose EZ pull thingy. Very easy to install and adjust. Just make sure you remove your engine cover because the little ball end will probably pop out on the clutch end of the cable while you are installing the device. Lube up the inside of the housing a little, add a little silicone to create a gasket to help keep dirt out, and make sure you locktite everything.
As for the clutch pull it has reduced about 30 percent as claimed. I just ordered a Moose EZ pull lever for my sons CR85, so before I install it on his bike, Im going to try it on Krushs bike in combination with his EZ pull device to see how much more it reduces the pull.
I can already predict that one or possibly both of these items on my bike within the next few weekends.
