TOTAL LOSS SYSTEM
http://cgi.ebay.com/ebaymotors/Battery- ... enameZWDVW
The stock CRF250X battery is a 4 amp/hour battery. I was looking at specs and came across this... a YTZ7S, same size, but a 6 amp/hour rating ( 50% higher and a $25, a real bargin). It is also a "Deep Cycle" style battery that is mountable in any position.
The stock CRF250X headlight is a dual 35watt Hi / Lo bulb. I fully charged the battery, and hooked it up on high beam ( wouldnt have mattered, both filliments are 35 watt)
In a "total loss" application, this battery lit the bulb at 100% for over an hour. From there is slowly degraded down to about 50% over the next 40 minutes. I would say it was good for a solid 1.5 hours of night riding.
Question? How much riding are you planning to do after dark? The battery costs less than a cheapie lighting coil + voltage regulator and works better too. Brits headlight is pretty dim at idle, looks good at 66,000 rpm...
If you dont plan on extended rides, this simple and cost effective solution just might be all you need....
