Lowering suspension on 98 cr125
ok guys and gals, I cant find a lowering link for the 98 cr125. So i'm back again needing a lil help. with getting this bike lowered for the wifey. I appreciate the help thanks Cheezy
There is something to be said about owning a CR500R. It's called BALLS...
http://www.werproducts.net/suspension.php
These guys are very experienced in lowering bikes. Between suspension and subframe mods, you should be able to get the bike as low as your wife needs.
Call em'!
Call em'!
Hye thanks for the replys, Bob your the man. agin i am humbled by your infinate knowledge.
Sure can and that would be great Thanks again CheezyA cat I ride with lowered his 98 125 for the missus. If you can tear down the forks and shock, I'll get you the info.
