Tall guys...
Tall guys...
If you are a big dood and use tall bars and off set clamps be carefull to keep you hands as close to the center line of the forks. Its easy to use forward offsets and roll your bars far forward. It may feel great in the garage but it will beat you up and tire you out quicker on the trail...
The "swinging" back and forth is supposed to change the steering behavior and use extra muscle force to get the same work done. But my experience is the effect is not HUGE but noticeable at different levels depending on rider...
Dood, I can tell when the engine is running, and when its not... Thats about it.M.F.D.B. wrote: depending on rider...
Re: Tall guys...
Fixed it for ya.M.F.D.B. wrote:If you are a big dude and use tall bars and off set clamps be carefull to keep you hands as close to the center line of the forks. Its easy to use forward offsets and roll your bars far forward. It may feel great in the garage but it will beat you up and tire you out quicker on the track...
Not to mention land with the body to far forward and you may find yourself looking for a soft place to tuck and roll.
2013 Dodger Charger 5.7 Hemi
http://www.prisonplanet.com
Your Amsoil Customer # 350882
If you got the clams, http://www.fasstco.com/products/flexx.shtml get the 116mm "ATV" bars, they are about 1" taller then the bike bars...
Unless you are 6' 8"+ I would say either or would be plenty, unless you like this look...bigjay wrote:do you use quad bars in conjunction with the risers or do you mean just use quad bars instead of the risers? those flexx bars are sic.. kinda mean to the pockets though. thanks guys!
We were just talking about that yesterday, they offer all the parts seperately and replace the set at half cost??AlisoBob wrote:
These are the "Quad Bend, 12 degree sweep" Flexx bars...
Totally worth the money, as long as you dont crash and bend them...
M.F.D.B. wrote:
Unless you are 6' 8"+ I would say either or would be plenty, unless you like this look...![]()
dude sign me up for those bannana bars, hell ill take a set of those 100 spokes and im painting my bike mopar green too.
after i get my gear all bought ( still need boots, roost guard that fits and pants) ill look into a set of those quad bends, ill look for a set of risers in the mean time.
Jay
I break stuff
I break stuff
Do the flip flop trick, only cost you 4 bolts from a hardware store...bigjay wrote: ill look into a set of those quad bends, ill look for a set of risers in the mean time.
You take the tops of your bar clamps, flip them under the bars and put another pair on top. All you need is a set of 4 longer bolts (and of coarse an extra set of clamps, which most people have already)...bigjay wrote:teach me this.. flip flop trick.. i must knowM.F.D.B. wrote: Do the flip flop trick, only cost you 4 bolts from a hardware store...
Needs to be longer then the bolts its replacing by the height of the clamp...bigjay wrote:huh, ill look for a set of clamps so i can give that a try, do you happen to know how much longer and what type of bolt is needed?
Just take the parts to the "Depot" with ya...
