CR500 Engine Jig
vito.a
CR500 Engine Jig
Post by vito.a »
I have a like new CR500 engine jig.  We used this while building our CR500 conversion.  This jig was built and then the holes were drilled on a CNC machine for exact location.  You can use this jig to weld up your new 500 engine mounts and when you're done the bolts will slide right in with perfect alignment.
CR500 jig 2.jpg (588.65 KiB) Viewed 1294 times
CR500 jig 1.jpg (328.97 KiB) Viewed 1294 times
