1986 CR500 clutch cover upgrade
Rustynuts
Post by Rustynuts »
In need of upgrading the cracked side cover on my 1986 CR
I can get a similar cover with the slanted top hose end to accommodate the existing rad hose from overseas
Or
Honda side cover with the removable clutch cover and the vertical hose flange. I think I would have to buy a different rad hose to fit the new location of the cover flange?
Is one better than the other? Any opinions?
The one overseas is a couple hundred bucks cheaper.
Not sure if the updated Honda cover would make the rad hose run against the pipe or not
Cheers
:D NO BAD DAYS :cool:
Rustynuts
Re: 1986 CR500 clutch cover upgrade
Post by Rustynuts »
Anyone know what hoses are required for newer cover upgrade with the vertical hose flange on a 86 CR500?
