New member in OR
dbur
New member in OR
Post by dbur »
Since I'm going to finally have medicare this year and can go to the hospital whenever I want I decided time to move from my heavy beast XR600 to a the much lighter CR500. My 2001 CR500 is 43 lbs lighter on paper and that feels marvelous. I mostly ride forest single track. It looks like my new beast is in need of a top end re-do so I'm now getting in to that. This forum doesn't seem to be terribly active. Is this the best place for technical and bike specific advice, or is there some other forum that is more active?
Thanks.
kott0n
Re: New member in OR
Post by kott0n »
It isn't super active but a few people still around. It's the only site still active dedicated to these bikes.
Where in OR? I'm in Vancouver WA and ride down near Estacada, OR and Clatskanie, OR. I only ride single track/logging roads but I do occasionally take it to the sand.
dbur
Post by dbur »
I'm in McMinnville, We usually ride the awesome Upper Nestucca single track trails.
cowboyona426
Post by cowboyona426 »
This is the place to be for CR500 info. It is pretty quiet usually but there are some good people here with a ton of great knowledge and experience with these bikes.
16 YZ 450FX
01 XR 400R
98 CR 500R
91 CR 500R
95 CR 250R
98 WR 250Z
91 XR 200R
kott0n
Post by kott0n »
That looks like fun. I find my self wanting to open up the 500 more and more. I like the more wide open type stuff or at least a healthy mix of trails/logging roads. I will say the 2 places I go are nice in the fact that the single trap continually loops back and crosses the logging roads so you are never on the trail for super long.
Of course part my hesitation for deep woods riding is this 1.4gallon tank. Its a 2006 crf250r and after the 1.6g tank gets modified, its about 1.4g.
I would be down to meet up though and do some riding.
dbur
Post by dbur »
I believe my stock CR500 tank is 2.4gal? And the petcock has no reserve position. I have a larger tank on but was thinking I could get by with the stock one. We usually do about 30 miles.
2001 CR500R
Engine Type: 491cc liquid-cooled single-cylinder two-stroke
Ground Clearance: 12.9 inches
Dry Weight: 222.7 pounds
Fuel Capacity: 2.4 gallons
What range are you getting with your stock tank?
Might not be doing much riding till the weather clears up. It gets much better if we can just get 4-6 days without rain so the moisture can soak in.
I have started a facebook group for the people we ride with. "Upper Nestucca Single Track Riders" Just a few members so far but thought that would be a good way to communicate ride info. Unfortunate I discovered there are people who are not actually on facebook, if you can believe that. :lol:
kott0n
Post by kott0n »
On the aluminum frame bikes you have to heat and push in the gas tank which reduces the volume.
I figure I'm getting about 15 miles out of the ~1.4 gallons.
I'm going to buy a Trailtech Vapor (local company Battlground, WA) to get a real idea of the range. The RPM/Speedo wont hurt either.
dbur
Post by dbur »
You might want to look at mounting a 1 gal RotopaX tank in front of your front number plate to get some more range. 1.4g is pretty small.
cowboyona426
kott0n wrote: January 8th, 2020, 9:18 am On the aluminum frame bikes you have to heat and push in the gas tank which reduces the volume.
Holy shit Batman, that's some major fuel consumption!
16 YZ 450FX
01 XR 400R
98 CR 500R
91 CR 500R
95 CR 250R
98 WR 250Z
91 XR 200R
No joke on the bad mileage.
I was typically able to get 60-70 miles out of my 95 on North Idaho single track with the stock 2.4 and 13/51 gearing.
dbur
Post by dbur »
Well that sounds more reasonable. I'd like to swap my std size tank back on if it can cover my rides. It's a real pain getting at the spark plug with the oversize tank. I had to make a tool to pull the cap back on.
cowboyona426
MojoScojo wrote: January 9th, 2020, 9:21 am No joke on the bad mileage.
Dang that's good, I think my 98 was more in the 35-40 range when it was getting low enough that I was glad to be back at or close to the truck.
16 YZ 450FX
01 XR 400R
98 CR 500R
91 CR 500R
95 CR 250R
98 WR 250Z
91 XR 200R
kott0n
Post by kott0n »
I'm probably estimating low but I don't really know for sure as I'm not logging anything.
I will say about 60% of riding is WFO on logging roads ripping through the gears and the rest is single track lugging it in 1st.
I have 13/48 gearing and being a 89 motor I have the lower 4th/5th.
kott0n
Post by kott0n »
I double checked. My font sprocket is a Moose that's stamped 14 16, so probably a 14 tooth, how confusing that is. The rear is a 49 tooth.
