Hi all I have a 94 cr500 but am I need of a transmission as mine is missing!!!!!
Locally are loads of 85-88 complete gearboxes but I don't seem to be able to find info on compatibility between years....
I have found they changed ratio in later years but could I install a complete transmission from an earlier model (close ratio I know )I'd be riding mx so no dunes etc as I'm in uk
Thanks in advance
Transmission issue desperate for expert help
You can use anything 1986-01 with your clutch parts, 86-87's need a output shaft bearing change at the sprocket.
