1985 CR500 Shock Rebound assembly question
cleblabe
Post by cleblabe »
After grinding the nut off which holds the valve on the shock shaft all of the rebound components fell out. I have a brass looking needle with an oring, a spring and two other parts which look to be spacers. Can anyone tell me how to reassemble these into the shock shaft. It has been months since I pulled it apart and can't remember how to put it back together.
Harley Davidson-The most efficient way to turn gasoline into noise without the benefit of horsepower.
