Aluminum sleeve
Aluminum sleeve
I know this isn't a popular idea with most cr5 guys but if anyone has tried it I'd like to hear about it. I have the thin sleeve 86 cylinder & there's a new aluminum sleeve out that seems like a great idea . My k5 runs really cool & the plating seems to last longer. The new AL sleeve is for the latter cylinders but I should be able to port match right?
- motardcr500
I'll try to make you a link or proper post for it. Takes a fair bit of labor to install.
k, I'm too lazy/busy to link each picture today
https://onedrive.live.com/?cid=BD4AA268 ... 2E9%213844
The base of the sleeve needs to be broken off to start with
I center off the base of the cylinder from known dimensions.
I didnt have the room to bore striat out the top so I went most of the way, flipped the cylinder and bored it top down, then invert it again and bore the counterbore for the aluminum sleeve.
Install the sleeve cold from the freezer and cylinder on a hot plate, you'll have plenty of time to locate the port alignment.
port or match what you wish, I tig the base of the sleeve in a few places just becasue i can.
Deck the cylinder and you're left sitting at a 88mm or so finish. Millenium charges the same to bore the cylinder up to size so don't get too concerned with finishing it. They'll like it to be +.007" of intended bore size but they also like to not have impurities imbedded in it so it must not be honed to size.
- motardcr500
I set them up with standard bore, I've sent w torque plate to Millenium with advise to keep it for future work, hopefully they think to use it for other guys projects too.
I have a cabinet of fixtures made now, haha.
