PWK 39 jetting question
Cody19670001
Post by Cody19670001 »
I just bought a PWK 39 from Sudco who says they are going to send it with their recommended jets in it. I have an FMF Gnarly with their Turbine Core muffler, on a stock motor 89 mm piston and no porting. I have been running the old PJ Carb with:
175 Main
55 Pilot
Stock 1368 needle
2nd Clip
2 turns out on the air screw
700 feet above sea level
30 to 50% humidity
14 oz flywheel weight
Pro X cast piston
This has been a good setting on the old PJ for Tulsa, Ok.
I'm probably nuts for taking off a carb that seems to be set up pretty well. I've just read all the posts about the night and day difference that the PWK 39 offers. I know Sudco is going to put their jet set up in it, what ever that is. Does any one have a recommendation?? Am I making a mistake making the change?
other
Post by other »
Yep, I recommend you ditch the Sudco 'recommended' jetting before you even try to run the bike ! It will come with a 60 pilot and 160 main. It blubs like a bitch off the bottom, and will seize as soon as you pass half revs under load, it's EVIL lean !
170 main (172 in soft dune sand)
55 pilot (can handle a 52, or even a 50, but I like the softer hit off the bottom from the 55)
Sudco needle is OK, but clip it up to second from bottom, or stick with your 1368.
Cut about 2 and a half coils off the idle screw spring so you can screw it in far enough to idle . . . .
and that should give you a half decent baseline to start tuning from . . . .
Once it's done right, the PWK is night and day better than the PJ . . . . .
I plan on doing the same thing. Still running on a well-jetted PJ with the DGN needle. The settings I have been recommended are: DGN needle 172 main, 45 pilot. all at about 2500ft. Good luck and post your results!
Cody19670001
I really appreciate the advice. On the DGN needle, any thoughts on starting clip position??
Thank you very much
Homeskillet
Post by Homeskillet »
Extended air-screw. That big carb can be a finicky bitch off-idle.
jar944
Post by jar944 »
The DGN was extremely lean on the straight diameter for me.
I'm running a DGK, 38 pilot, 175main & #6 slide.
@ 400-2000' elevation
vito.a
Post by vito.a »
You guys need to borrow a PWK Air Striker. It will completely change your bike!
