http://cr500riders.com/cgi/yabb/YaBB.pl ... 645955/0#4
I'll have a batch of spacers available soon.
84-86 Cylinder Spacer for Long Rod
Re: 84-86 Cylinder Spacer for Long Rod
Sorry for the delay, the spacers are done and I will be picking them up on Monday.TecRider wrote:http://cr500riders.com/cgi/yabb/YaBB.pl ... 645955/0#4
I only had (10) made, let me know if you'd like one.
- louis mielke
The spacers are in, I have eight left, Louis's shipped out this evening.louis mielke wrote:I need 2
Price is $35 US apiece (Canadian $ is down and AL has gone up), there will be free shipping. (Canada and US)
I accept PayPal: gsivyer at yahoo dot CA (not .com)
Send me an email to the address listed above since PM's are hit and miss. Be sure to include a note saying who you are here, as I don't know everyone's name.
*** Please note that these spacers are designed for the early model jugs, with the smaller liner OD. If you have had your cases bored to accept the larger diameter liner of the late model jugs, you will have to modify the spacer accordingly. Also, according to Roostius, you will need to make new or modify the head stay. Pipe mounts may also have to be modified, since you are raising the pipe up 5mm. Clearance under the tank may also be an issue. Port timing changes slightly, not that us mere mortals will notice. But, on a bright note, you will gain more coolant hose/expansion chamber clearance around the water pump on the '85-'86 models.
https://fbcdn-sphotos-h-a.akamaihd.net/ ... fce438c82f
Couldn't get the image link to work, so I made it a url instead.
