gen1 to gen2or3 swing arm swap?
blowinsmoke
Post by blowinsmoke »
Can anyone tell me if I can change the swing arm on my 1998cr250 to a later one with the larger axle? The adjustment bolt broke off in the swing arm and my wheel is hammered so if I can change to the newer swing arm I could use the same spares as my other bikes.
motardcr500
Post by motardcr500 »
Did you ever try the swap?
If so, what were the results?
With frame and suspension Geometry being ticklish as to how easy it is to change handling characteristics I'm not sure I would try it.... Just curious..
